Hey Larry in NE Ohio - does it run?
Tim in New York
11-10-2007 16:04:18
Larry,
I am exactly at the same point as you today with my 700 Diesel. Lots of white smoke coming out the exhaust when I crank the engine, but I can't get it to fire. Mine has been sitting for 6 or 7 years without running - have replaced all the filters and lined the tank. Did you figure out anything that may help me? Think I will try to tow it tomorrow.
Tim
caseman-d
11-15-2007 16:21:48
 Re: Hey Larry in NE Ohio - does it run? in reply to watsonsgotit, 11-10-2007 16:04:18
Larry,
Put in about 6 th gear and you will have it running in about 25 ft. Think positive third party imagethird party imagethird party imagethird party imagethird party imagethird party imagethird party imagethird party image
larryNeohiocase
11-15-2007 11:31:03
 Re: Hey Larry in NE Ohio - does it run? in reply to Tim in New York, 11-10-2007 16:04:18
Talk about 50/50 chances! Ok so 2 of the injectors are good and 2 need rebuilt. Gave them the go ahead and will pick up them Friday after work. I hope to install Friday evening and get the beast hooked up and pulled down the driveway saturday. You think that 1000-1200 foot drive would be long enough? LOL
larryNeohiocase
11-15-2007 06:05:24
Update: LOL
Injectors from the "spare" engine would be like $54.00 each to rebuild. Pulled the injectors out of the engine that is actually in the tractor and dropped them off yesterday. Pump timing looks to be on the money. And yes I bought 2 new batteries and they are installed so the beast is craking over just great.
What do you guys think about pulling the critter instead of using the starter once I get the injectors back in her? Is there really that much of a difference?
Thanks guys,
Larry
LarryNeohiocase
11-13-2007 05:37:18
Sorry Tim, I"ve been out for a while and our internet at the house has been goofed up! TYVM Time Warner Cable!!!!
I readjusted the valves according to the shop manual and drained the old fuel just in case. Broke the lines loose at the pump cranked it over and looks like I have good fuel flow. Took the lines loose from the injectors and same there. So I"m assuming one of 2 things, either injectors or injector pump timing. Dropped off the 4 injectors from the "spare" engine that I got with the tractor to have them cleaned and tested. Waiting to hear back on those. This week I"ll reset the pump timing and hopefully install the injectors and see what happens.
I picked up a 1962 830 COM this past weekend for parts but I"m now thinking that I just may swap the engine from the 801B over to the 830 COM... Any feedback/suggestions?
Thanks,
Larry
Gene Dotson
11-11-2007 04:20:41
Tim;
Which pump does the tractor have? The 1958 model used the American Bosch round pump and the 1959 model used the inline German Bosch pump. The injectors are the same for both systems.
White smoke indicates unburned fuel. This may indicate that the injector pintles are sticking or not closing properly and allowing fuel to be squirted into the cylinders and not properly sprayed. If you can get the tractor started by pulling it, they may free up and run alright, but most likely the injectors will have to be removed and the pintle tips relapped or replaced. Frequent use of ether tends to blow carbon back into the injectors and causing them to not seat properly.
I have a 1959 701B and I have to do this occasionally to get a good spray pattern.
I really like the tractor and would like to have another one someday... Gene
caseman-d
11-10-2007 19:44:53
 Re: Hey Larry in NE Ohio - does it run? in reply to JW2, 11-10-2007 16:04:18
Tim,
What model 700 do you have?? I have a 702B. When it sits for a long time it's hard to start. I get lots of smoke and no fire. I found if I just crank it for short periods then it seems to fire faster. I hate to use either to start mine but I do have a couple of case tractors thats the only way it will start unless pulled.
caseman-d
Tim in New York
11-11-2007 05:53:02
 Re: Hey Larry in NE Ohio - does it run? in reply to caseman-d, 11-10-2007 19:44:53
Gene, Caseman,
Thanks for the information. I have a 59 701 B, a late model with the inline pump. I hoped to avoid ether - we had a 430 that we tore down a few times due to Dad's insistence on using ether to start it. But I decided to buy a can today and use it very carefully. The manifold heater does not work either and that is not helping matters any.
Like Larry, I could not get fuel to run out the bleed valve on the 3rd filter. But I do see seepage around the line and the volume of white smoke makes me think I do have the system primed. I seem to have lots of compression, as I can't get it to spin real fast, even with the deep cell battery from my boat.
I'll let you know how it goes today.
Thanks,
Tim
