suggested value
patsdeere
11-10-2007 00:13:21
I think this thing is a C, but am not 100% sure. It does have a sn plate, but I just can't read it. What do you think is the approximate value. The sheet metal is fair and the engine is free.
third party image
third party image
Thanks.
caseman-d
11-10-2007 19:25:05
 Re: suggested value in reply to louisville ohio, 11-10-2007 00:13:21
I agree with it being a L. There was one around this area a few years ago and they wanted 1000.00, I know it sold but not sure if they got the 1000.00 for it. Was another one I think the guy wanted 1200.00 for it. So I would sayfair price is between 1000.00 and 1800.00.
caseman-d
Steve (DE)
11-10-2007 16:22:27
 Re: suggested value in reply to patsdeere, 11-10-2007 00:13:21
Usually if there is a strap over the middle of the fuel tank as well as on the end, then its an L.
Brian in Ohio
11-10-2007 12:11:14
I'm leaning with that being an L and not a C. If you can post a pic of hte back end of the tractor, it will be a dead giveaway.
Where is the serial number plate located? On the toolbox behind the steering wheel, or on the right side of the radiator bolster? On the carb side of the block, close to the water pump, there should be a small area mcahined flat, and the serial number should be stamped there. Post that number, and we can tell you the year.
patsdeere
11-10-2007 22:40:09
 Re: suggested value in reply to Brian in Ohio, 11-10-2007 12:11:14
It is located on the toolbox behind the steering wheel.
mEl
11-10-2007 03:45:15
I have no idea what it is worth but it loooks to me like it is an L, I can't see the engine sideplates where you access the bottom end but several things just look different than a C. Closer pictures of the sides of the engine area would be helpful
Gene Dotson
11-10-2007 09:03:25
 Re: suggested value in reply to mEl, 11-10-2007 03:45:15
mEL;
I think you are right on. The water manifold on the side is a good indication... Gene
Tom Railsback
11-10-2007 13:17:28
 Re: suggested value in reply to Gene Dotson, 11-10-2007 09:03:25
I agree that it's an L and it looks as if it has the Kingston carburetor.
