Crawler track tensioner
Keith
01-09-2000 16:54:44
Hi everyone!
Yes, I know most of you guys run on rubber wheels but...I've got a question about track tensioners. My case 450 has a tensioner that won't hold. I fill it with grease and after working it a bit the track starts to sag big time. Needless to say quite a pain in the butt when I forget to check and the track is hanging off the idler! My guess is the tensioner is a piston that is filled with grease and expands against a coil spring. Does anyone know if there is an O-ring inside or a sealing puck of some sort? How do I remove? I would think that I need to pull the front idler off the track. Are there any special tricks?
Thanks guys!
Keith
