What size trailer plow will a dc pull
Dale Meacham
11-09-2007 18:42:05
I have a 51 DC with the eagle hitch. I don't have wheel weights or fluid in the tires. I know where there is a 3 bottom 12" trailer Case plow. I am looking for some whel weights for my tractor so later that will play in my favor. The soil around here has some red clay but most plowed fields have better soil. Any help would be greatly appreciated.
Hawkeye Gold
11-11-2007 19:41:18
 Re: What size trailer plow will a dc pull in reply to Dale Meacham, 11-09-2007 18:42:05
My DC hasn't pulled a plow since I was a boy. Dad put big sleeves and pistons in it. We pulled 3 16"'s then in NW Iowa black dirt with no problem.
Glenn FitzGerald
11-11-2007 05:51:14
Dad bought our '51 new. It's pulled 2-14's in first/second gear with fluid in rear tires for 56 years...Green Bay, Wisconsin.
Glenn F.
John Saeli
11-10-2007 06:18:49
Hey Dale: Never saw a '51 w/ Eagle Hitch. The serial # on a 51 would start with 55-----. She will play w/ 3 12's.
Dale Rainwater
11-13-2007 17:44:47
 Re: What size trailer plow will a dc pull in reply to John Saeli, 11-10-2007 06:18:49
I have a 1951 DC with an eagle hitch. Serial number starts with 55. (It is definitely not a 1952 DC transmission case.) This transmission case looks just like the '51 and prior, it just has the rock shaft housing that attaches to the upper lift arms. This must be a sample or test tractor for the eagle hitch. And, the transmission case number was not listed in the Case DC parts catalogs.
JGarner
11-10-2007 04:26:02
Depends on some on altitude too. Our SC would pull 3 14s in Central Texas black gumbo (fairly level ground about 1,000 ft above sea level). Same tractor would only pull 2 in Northwest Colorado (up pretty steep hilly fields in adobe soil 7,000 feet above sea level) DC is one level up from SC.
Mike in MI
11-09-2007 19:10:30
Dale,My dad had a DC Case and he pulled 3x14's with it in clay ground. Had plenty of power but just could'nt keep the front end down. We was thinking it may had a step up kit put in? It should pull the 3x12's ok. Mike
Gene Dotson
11-09-2007 19:01:17
Dale;
3-12's will be a good match for the tractor as it is now. More common is 3-14"s with weights and fluid in the tires. If you anticipate plowing a lot of heavy trash or fodder, then 2-16's will work well, especially with weights... Gene
