case 1816
RIC THOMPSON
11-09-2007 01:18:11
I HAVE A 1816 THAT WAS DOING FINE ,I BLEW A FRONT TIRE AND IT TURNED OVER.SO I CHANGED THE FLUID.THEN IT STARTED MESSING UP FIRST THE RIGHT SIDE QUIT, THEN THE LEFT SIDE QUIT AND THE RIGHT STARTED WORKING FOR AWHILE.I CHANGED THE FLUID AGAIN STILL THE SAME. SO I PUT A DRIVE MOTOR IN ,SO NOW BOTH DRIVES ARE NEW. NOW IT SOUNDS LIKE AIR.SO I GET THE AIR OUT BY CRACKING THE DRIVE HOSE ON THE R DRIVE.HELL NOW IT IS WORKING I AM SO HAPPY .I TAKE IT OUT ON THE DIRT ROAD AND SPIN IT LEFT AND RIGHT 3X EACH WAY.GO TO PARK IT AND DON'T YOU KNOW, THE LEFT STOPS WORKING.I AM PULLING MY HAIR NOW.SO I READ THE MANUAL.I PULL THE LEFT SIDE PUMP MOTOR (variable speed motor) change the linkage pin that was falling out, check the front pump in it,to make sure that the pin is not boken,as in my books..while having it out I check the valve. put it back together,only to find the right side is NOT working right.So I check for air,fluid and linkage out.Now when it first starts it wants to move forward but does not. It will go backwards. But when you try to go forward it fells like you go through it and it wants to back up. What the hell is going on .I went to hydraulic shop here in pensacola fl.but they do not want to bother with it.They told me to keep going what I am. I can not do no more.I need someone to help with some advise that makes sence any help would be appreicated ric .ph.850-939-0890 thanks
mEl
11-10-2007 04:08:44
 Re: case 1816 in reply to RIC THOMPSON, 11-09-2007 01:18:11
Your situation is a puzzler, i have worked on many hydrostats and never once had to bleed the air out but if you are getting air then it is obvious that there is a suction leak before the charge pump inlet. What oil are you useing, not all oils are suitable for hydrostats. Case now uses 10/30 in all recent units with a sepecial additive called HTO, an oil conditioner. Most drive problems with the 1816 can be traced directly to oily slippy drive belts, I would check them for clean and dry and tension. I have corrected many problems right there. Maybe this will get some more people involved in your post
