Case 2290 loader
jpd
11-08-2007 19:18:36
Where to plumb hyds for loader so you dont have to connect into remotes?
turbo
11-08-2007 20:01:18
 Re: Case 2290 loader in reply to jpd, 11-08-2007 19:18:36
90 series hydraulics are flow compensated and there is a signal line from the remote valves and 3pt valve plus check valves in each valve to make the hydraulic pump perform properly. In other words, the signal line tells the pump the volume you need at a required pressure. Suggest using tractor valves and add more to the stack if needed. Auxiliary valves such as Gresen or Prince, whether they are open center or closed center will not be very kind to your flow compensated hydraulic pump.
