oldest working case tractor?
smith tx
11-08-2007 05:50:24
who has the oldest working case tractor (used daily on farm)? just wondering, thanks
James Herrman
11-11-2007 21:07:23
 Re: oldest working case tractor? in reply to smith tx, 11-08-2007 05:50:24
I use a 1931 Case CC for field work. Jim in ILL.
C. Amick
11-10-2007 19:31:22
A 1945 SC is my oldest. I use it to run a pull-type rotary mower and trail type 2-bottom plows. It's a kerosene tractor.
Gene Dotson
11-08-2007 20:40:06
My oldest working tractor is a 1940 Case V. It has an aftermarket hydraulic pump and I have a hydraulic dump trailer I use often with this tractor... Gene
Tom (Ks)
11-08-2007 17:35:32
My uncle grinds feed with a CC and I think it is a 1936.
Thad
11-08-2007 16:53:01
In my area lots of VACs some SCs and DCs. Not much older than that being used very much. Most of the CCs and Ls are used at parades and local pulls. That starter makes the others look more appealing to most folks. Thad
( sonny )
11-08-2007 06:35:24
DORI
find the i.d. tag,get the numbers,go to research & info , on the left column of this page , go to serial numbers & see what you come up with.
sonny
dori lynne
11-08-2007 06:14:08
hi from gunbarrel city texas..... .i was wondering if you could tell me how i go about finding out the year model of my case tractor?any information you could give me would be greatly appreciated.Thanks,dori
JGarner
11-08-2007 07:58:10
 Re: oldest working case tractor? in reply to dori lynne, 11-08-2007 06:14:08
Pre 60s-80s serial number tractors take the first 2 numbers in the serial number and subtract 4. The result will be the year model.
60-80 series numbers go to serial numbers in the left hand navigation bar on this site.
Tom Railsback
11-08-2007 15:13:42
 Re: oldest working case tractor? in reply to JGarner, 11-08-2007 07:58:10
Your formula only works on 7 digit serial numbers; for 6 digit numbers, take the 1st and 4th and subtract 3.
