Larry,Found this in archive search
msb
11-07-2007 14:47:56
Link Maybe it will help you.
mEl
11-07-2007 16:21:12
 Re: Larry,Found this in archive search in reply to msb, 11-07-2007 14:47:56
you didn't state that you did so I am going to suggest that you loosen the fuel lines at the injectors and turn it over till you get good flow there. There may be a spot of air in the pump that will not move with the high pressure lines closed off. Maybe someone else can offer more advice that is helpful.
LarryNeohiocase
11-08-2007 06:07:52
 Re: Larry,Found this in archive search in reply to mEl, 11-07-2007 16:21:12
Ok so new batteries installed last night and I tried to pour fuel directly into the final fuel filter but it appeared to be full. Removed the bleeder screw and that looked empty. I never did get fuel to flow out of the final filter bleed screw. Cranked and cranked didn't start but looks like there is more volume of white smoke comming from the exhauxt. I also held a gas soaked rag over the intake and that didn't seem to make any difference.
Removed 2 of the lines off of the PSB inj pump and cranked engine ended up seeing little spurts of fuel comming out. Removed pressure relief valve and it was stuck so blew it out and got it moving again. (It had a ton of crap in it.) Does this thing come apart so that I can clean the inside?
Tonight we are gonna run through the valve adjustments and make sure that there is enough compression. I'll prolly open the lines at the injectors and crank the thing over just to make sure that fuel is getting that far. My worry is that there is not enough fuel getting to the chambers for it to fire. I would have thought that I would have seen a little bit more pressure at the injection pump when I removed the line.
I also noticed last night that the fuel pedel is almost all the way down and the linkage feel like it's binding.
Would that have any effect on starting the beast? Would it be a good idea to remove the injectors and disassemble them for cleaning or should that be done at a shop?
