Hot miss on DC
36 A
11-06-2007 19:37:10
When plowing or disking it starts to stutter when opening it up and it just gets worse till it wont run.Let it sit for a while runs good and starts all over.I think it boils the gas in the carb and line .so say that is not it.What do you guys think?
mEl
11-07-2007 03:22:43
 Re: Hot miss on DC in reply to 36 A, 11-06-2007 19:37:10
Had a farmall m once come to the dealership that I work at, put it on the dyno and duplicated the problem, found that the valve adjustment was way off, all to tight as the engine heated up the valves were not closing due to the expansion of the valve train. Gene is right on the plug deal, btw we have no luck with champ plugs, we use autolite, i believe 3116, there are two in the right heat range, one standard tip, one extended. Don"t overlook a coil or condenser if the spark is yellow or weak.
Gene Dotson
11-06-2007 19:41:27
I would try a colder spark plug, like maybe a D 15. Had a VC that did that with D21's and replaced them with D16's and it ran fine... Gene
