580C Master Cylinders
CKerr
11-06-2007 15:19:27
Is there a good way to check to see if the brake master cylinders are working properly before I put everything back together. I took them out because I could not get fluid to run out after I bled them. It does not look like anything is wrong and I would like to clean everything back up
and check it somehow before installing them. Otherwise I was just thinking I should spend 350 bucks and put all new in???
Thanks for your time
Roger (Mi)
11-07-2007 05:50:37
 580C Master Cylinders kits in reply to CKerr, 11-06-2007 15:19:27
The master cylinders can be bench tested. Clamp a master cylinder in a vise. Make sure the reservoir is at least 1/2 full. Using a large screw driver, push on the master cylinder piston while keeping a loose finger over fluid outlet. After a few pushes, fluid should squirt out from under your loose finger. If it doesn't, the master cylinder needs to be rebuilt or replaced. I've discovered that the dealer's price for master cylinder kits can be expensive. Since it's just the master cylinder piston seal that usually goes bad, I've looked at the seal size and head for an automotive store. They can sell you a slave cylinder kit from some other application that has the correct seal for your master cylinder at a fraction of the cost of the dealer's price. Just make sure the master cylinder is well honed out and cleaned before reassembly. If the master cylinder bore is badly rusted and pitted, you may have to bite the bullet and buy new ones.
C Kerr
11-07-2007 08:39:38
 Re: 580C Master Cylinders kits in reply to Roger (Mi), 11-07-2007 05:50:37
Thanks for the info Roger. It looks like I have to bite the bullet!:)
