case sc decals and chrome
dwayneet
11-05-2007 15:21:18
Wondering if there is a difference in the quality of the decals for my case sc. I'm trying to make it original as possible, also does the year of the tractor matter? It is a 1942, also still looking for one chrome strip for the hood? thanks Dwayneet
dwayneet
11-07-2007 13:25:56
 Re: case sc decals and chrome in reply to dwayneet, 11-05-2007 15:21:18
thanks for the info on the chrome. but still acouple of questions on the decals. are all years the same? where to get good original quality decals?
watsosngotit
11-08-2007 16:36:02
 Re: case sc decals and chrome in reply to dwayneet, 11-07-2007 13:25:56
Decals should be the same for all sc's. Try maple hunter decals for good quality vinal cuts.
toomanycases
11-05-2007 23:23:45
JGarner, Could I get the name or address of the ones that can make the strips? I need them at least 4 D's & 3 SC. Have had no luck on finding any chrome on VWs at this point. Thanks, Chuck
JGarner
11-06-2007 05:23:30
 Re: case sc decals and chrome in reply to toomanycases, 11-05-2007 23:23:45
They don't make the strips, they refurbish existing ones which would include cutting existing ones down and reforming ends and welding two shorter pieces together, grinding and polishing weld to make the joint unnoticeable. I called a couple of them and they indicated that no matter how bent up a piece was they could restore it (its been about a year ago but the fee was by the hour and it was $24/hr, real bad pieces could get expensive).
The only stipulation was that they needed one piece in reasonably good shape as a guide. The piece didn't have to be perfect, just a section of it with the right shape and one good end. If you are making one from two or cutting one down then you would also need to supply an accurate length.
Link
Link
Link
http://eastcoastrestorations.com/Resto-trim.asp
watsonsgotit
11-05-2007 16:14:43
I have been told that VW crome will work. If I were choosing decals for a nice neat job, I would only use vinal cut. They are of better quality and make your restoration much nicer. It is well worth a little extra money.
JGarner
11-05-2007 17:42:47
 Re: case sc decals and chrome in reply to watsonsgotit, 11-05-2007 16:14:43
Will the VW trim strips work only on the older SC's or is it the right shape for any of them including the 30 series? I have found several places back East that will refurbish the stainless steel trim including cut to length or welding pieces together and reshaping ends.
