VAC What did I do wrong?
vacnewbie
11-05-2007 12:40:28
I removed the belt pulley/hydraulic unit because it was leaking. I fabricated a plate to cover the opening so I could run the tractor while I was repairing the unit. I refilled tourque tube with fluid up to the fill hole. Ran the tractor for 20 minutes or so with no issues a few days ago. Today, when I started the tractor, oil came out of the flywheel cover and the timing cover.
Joe (Wa)
11-05-2007 17:56:54
 Re: VAC What did I do wrong? in reply to vacnewbie, 11-05-2007 12:40:28
Are you sure it is fresh oil from the torque tube or from the engine rear main seal?
You filled it to the lip of the 3/4" npt plug opening on the left side of the torque tube?
Factory oil for tractors w/o the engine mounted live hyd pump was SAE 90 although the clutch shaft seal is the same for torque tubes used for hyd reservoir.
Your pulley housing may not have been shimmed to provide enough gear backlash forcing the clutch shaft toward the transmission slightly and now the seal lip is riding partly on the ridge of the former wear area on the shaft? The shaft may have more run out w/o the gear mesh causing the seal lip to trip over the former wear?
Joe
J heitkemper
11-05-2007 20:51:43
 Re: VAC What did I do wrong? in reply to Joe (Wa), 11-05-2007 17:56:54
Good answers Joe ,, I agree with Newbie and Your prognosis that the seal is wearing a new area now ,,you might try LUCAS hub seal in the torque tube, My FIX -IT experience with these sort of problems , Might keep you from having to do seal job,
vacnewbie
11-05-2007 18:19:59
I did use the 90w oil and filled it to the lip of the plug on the left side of the engine. There were approx 7 shims between the torque tube and belt pulley housing. My thought was along the same lines as your last statement, yours being a lot more technical than mine. If I fix and replace pump, could it possibly put things back in place? Or is it more likely that I am going to have to tear it down and replace shafts or seals?
Joe (Wa)
11-05-2007 23:23:54
 Re: VAC What did I do wrong? in reply to vacnewbie, 11-05-2007 18:19:59
No telling if remounting the pulley will stop the leak, the seal could be close to 60 years old, probably not too forgiving once disturbed. I've never tried a seal conditioner like Lucas, no clue on that.
I think I would continue with the pulley repairs, remount with the same 7 shims checking pulley doesn't lock up as you tighten the nuts. Check backlash, adjust if necessary and run it, see if you get lucky.
There is only one front shaft seal just aft of the clutch, split the tractor just as if for clutch work. I don't know if Case has discontinued the original seal but I would go with the equivalent by CR or other major brand. Modern seals have much narrower retainers so it is generally possible to mount it so the lip isn�t running on the worn shaft area.
Joe
Hoss in Maine
11-05-2007 15:35:22
Sounds like you omited a vent or breather.Hope you get her straightend out. Later,Hoss
