Case 1370 Hydraulics
Craig Powell
11-04-2007 06:43:34
The oring on the bypass piston on the hydraulics on my 1370 keeps blowing out. I can change it without removing the valve body ...."by feel", there is a cap with springs and shims for setting the pressure, a pilot piston and so on. The oring is marked #7 in the shop manual exploded view. Is something else worn out? What is the purpose of the pilot and main piston on the bypass? Does one unload first and throw the hydraulic lever back to the neutral position?
Craig Powell
11-04-2007 07:55:45
 Re: Case 1370 Hydraulics in reply to Craig Powell, 11-04-2007 06:43:34
I should add...thanks for any advice!
