low cluth petal on 530 Case construction back hoe
Pat Goggin
11-04-2007 04:52:11
I have a 1963 #530 case construction back hoe -GAS and the clutch slips .Oil level is good ,but the petal takes a hold right at the bottom ,but won't go up a hill. Can any one help me?THANKS
mEl
11-06-2007 04:08:32
 Re: low cluth petal on 530 Case construction back hoe in reply to Pat Goggin, 11-04-2007 04:52:11
is it a Torque converter tractor or dry clutch, we need more info to answer your post.the tractors were made both ways and a TC tractor will not go up steep grades in the higher gears it will just come to a complete stall with the engine revved up, thats its nature, if it is a dry clutch tractor, its clutch time!!!!
pat goggin
11-10-2007 05:12:46
 Re: low cluth petal on 530 Case construction back hoe in reply to mEl, 11-06-2007 04:08:32
i have a wet clutch in #530 Case backe hoe. Pat
mEl
11-10-2007 14:56:20
 Re: low cluth petal on 530 Case construction back hoe in reply to pat goggin, 11-10-2007 05:12:46
Pat you have a torque converter type drive in your unit, not to be confused with a wet clutch, slippage is normal with your setup, but you should have enought power transfer to do work in the lower gears, but if you head uphill in hi gear it will "stall", the engine stays revved up but fwd motion stops. There is also a direct drive lever opposite the throttle that locks the tc unit into "direct drive" and the engine should stall if you allow it to lug down without unlocking the direct drive. keep looking at future posts and back through past ones. The TC works best when the engine is at full rpm as far as transmitting torque. It is a different drive and must be gotten used to! Hopefull yours is in good condition and you just need to learn its proper operation as they are expensive to repair.
