case 5140 therostat-cooling
GITOAD
11-03-2007 15:48:45
I have a case 5140 that is not coming up to temperature. A dumb question but is the thermostat at the top of the engine where the top radiator hose connects? It just doesnt look like it could be..... .!! What temp might I use?
mEl
11-03-2007 18:38:57
 Re: case 5140 therostat-cooling in reply to GITOAD, 11-03-2007 15:48:45
the thermostat is in the casting bolted to the head where the upper hose goes on, it sits vertically and uses a thich squareish rubber ring instead of a gasket. I recommend useing a case/ih thermostat as they seem to be much higher quality than aftermarket ones also they are designed just for the consolidated diesel engine.your dealer will know what temp to sell you. also there is an air bleed hole built in that should be on top.
