oil pressure adjustment
j.kemp
11-02-2007 05:17:10
Does anyone know how to adjust a DC oil Pump / and or Releif valve , THANK YOU
mEl
11-02-2007 17:55:52
 Re: oil pressure adjustment in reply to j.kemp, 11-02-2007 05:17:10
Drain the oil down and remove the left hand rear side plate on the oil pan. On the pump you will see a long 7/8 nut sticking out toward the left side of the tractor, it contains a spring which controls oil pressure. Inside the pump body is a plunger which is pushed open by oil pressure allowing excess oil back to the pump return.If this plunger is stuck open you will have no pressure at all idling and very little at w/o throttle. Remove the plunger and look at the inner(solid ) end. Usually they have a wear area apparent, take emery and clean up any rough edges and reinstall. If the pump and bearings are good, the pressure can be adjusted up by adding washers under the spring in the cap.
j kemp
11-03-2007 06:32:37
 Re: oil pressure adjustment in reply to mEl, 11-02-2007 17:55:52
mEL, Would it be O.K> if I called you sometime ?,, THank You
mEl
11-03-2007 18:49:17
 Re: oil pressure adjustment in reply to j kemp, 11-03-2007 06:32:37
sure you may call after 5:00 PM EST 570 435 0861
Bob Smith
11-02-2007 13:33:59
I recently inherited a VAC form my Fater-in-law and he was the type that never changed the oil in it! It only had about 5 pounds of oil pressure the entire 12 years I have been around the tractor.
After it came to me the very first thing I did was change the oil and filter,
After putting in clean SAE 30 in it she has 30 pound of oil pressure.
So if you haven't already changed the oil( I'm sure you have if your anything like me!)I would give that a try first before getting into the pump.
I was shocked at how much the pressure came up!
JGarner
11-03-2007 07:01:00
 Re: oil pressure adjustment in reply to Bob Smith, 11-02-2007 13:33:59
Bob, changing the oil was one of the first things I did on my 630. as the oil looked thin like 10W-30 and the Case owners manual said low viscosity oil could cause this. You are right though some folks don't see the value in routine maintenance. (<:
I am pretty sure now after reading the response above and the exerpts on the oil pump in my Case dealers service manual that the relief valve plunger is in backward or stuck. The manual said to never add washers to increase spring force. They recommend getting a new spring (which Case has probably retired). I don't see a problem with adding washers as long as it is done in moderation and not to the point of stacking the spring. This will cause abnormally high oil pressure. If these springs take a set over time they were designed incorrectly or the wrong spring material was chosen. We use power springs in some of our high performance equipment in the oilfield service company I have worked for for 35 years. We have had some of this equipment in wells about a mile under the water/wellbore surface and they do not exhibit fatigue, but then again our engineers made sure the spring design and materials were correct. From reading the Case service manual I am not so sure their engineers were so careful. Cheaper to remove an oil pan than pull a string of pipe from a well in 5,000 feet of water!!
mEl
11-04-2007 03:47:58
 Re: oil pressure adjustment in reply to JGarner, 11-03-2007 07:01:00
J Garner, the plunger is hollow allowing the spring to go into it and is appx. 1.25 ?? long. Reversing it in its bore would make assembly impossible as spring would stack long before the threads would engage in the DC's case or the cap and roll pin could be installed in the others case
JGarner
11-04-2007 19:46:00
 Re: oil pressure adjustment in reply to mEl, 11-04-2007 03:47:58
Thanks, good info. Looks like I will take it apart and check before I start working her hard. Everything I am reading and hearing points to the relief valve being stuck open. Good to know it can't be assembled backward. That eliminates one possibility.I would like to narrow it down before I drop the pan.
Mind if I call sometime too? Don't know how savy you are on the 30 series tractors but any information is good information.
Jim Garner
mEl
11-05-2007 02:43:43
 Re: oil pressure adjustment in reply to JGarner, 11-04-2007 19:46:00
J Garner,, no problem, available most eves after 530.
JGarner
11-02-2007 10:41:42
Ditto for a 630.
The former owner said he removed and cleaned the pump when the engine was bebuilt. I am suspicious that it was not reassembled correctly or the relief valve adjustment is off. I am only getting about 3-5 psi on 2 different gauges.
