730 steering
INCase
11-01-2007 18:44:41
How does the front steering shaft come apart on the 730s. THere is a universal joint in front of the engine but I didn"t see how it comes apart. Thanks.
mEl
11-02-2007 03:55:48
 Re: 730 steering in reply to INCase, 11-01-2007 18:44:41
A roll pin secures the front yoke to the steering unit shaft, drive it out and the yoke will drive off the shaft, worse case you may have to heat it to loosen it up
cahess
11-02-2007 06:24:07
 Re: 730 steering in reply to mEl, 11-02-2007 03:55:48
Napa has repair parts for your steering u joints. Front one is a needle bearing cross others are plain an just need to be repacked.
INCase
11-02-2007 08:40:51
 Re: 730 steering in reply to cahess, 11-02-2007 06:24:07
Thanks for the info. I"ll have to look again for the pin and dig the 50 years worth of grease and dirt off the shaft.
