case-o-matic 730
rcw
11-01-2007 17:15:27
I have a case 730 with case-o-matic that i pull in the antique classes. The transmission seems to be getting weaker. Is there anything that can be done to increase the hydraulic pressure of the torque convertor???
mEl
11-02-2007 04:23:05
 Re: case-o-matic 730 in reply to rcw, 11-01-2007 17:15:27
What do you mean by "the transmission is getting weaker" If the torque converter is not filling properly the "stall speed " will increase causing the engine to rev higher than what would be normal and not putting engine power back through the drive. There is a torque converter pressure regulator on the TC unit internal. this valve controls the pressure inside the torque converter to provide proper fill of the TC unit. Get a gage and a book and check your pressures on the system then get back to us, there are a few good minds on here that should be able to help you out. Make sure that your Hi Idle setting is at or above max and that your governor is set to be very responsive as good stall speed is vital to a TC proper operation. Also. hook it to something that will not move with a good strong chain,Lock the brakes, be safe, put it in 8th gear and use the TC as a dyno, put a good timing light with a digital tach on it,put it wide open and let it warm up a bit under full load in gear, then set the carb (if gas)and ign timing to max rpm on the digital tach, you won't know how much power you have , but you will have all that the engine is capable of. the eng must be at max for the TC to work well. If a diesel, High idle is just as important but obviously the timing light tach is out unless you have a fancy one for the new diesels.if your tractor tach works you could use that for a reference. Hope this helps, mEl
cahess
11-02-2007 06:38:46
 Re: case-o-matic 730 in reply to mEl, 11-02-2007 04:23:05
Ihave 301 diesel an doing as you said i get 1900static rpm than as i leave it start to move it will drop some.Might try tch oil again if i pull it in pull. Just look an reminess these days.
Thomas J
11-02-2007 04:57:07
I have an 830 case-o-matic that drops clutch pressure when you slow the engine in direct drive and tractor will come to a stop. When engine is at 1200 rpms or higher the pressure is full and it stays in direct drive. What is the problem?
INCase
11-02-2007 09:01:58
 Re: case-o-matic 730 in reply to Thomas J, 11-02-2007 04:57:07
if there is something wrong with pressures. there are relief and regulator valves and seals internally that can go wrong causing the pressure to be low and having things not work as everything is hydraulicly controled.
Others have said in another post: >>>>>>>>>>>>>>>>>>>>>>>>>>>
"These would be my suggestions RE: performance/pressure issues without splitting unit. A) Filter
B) Fluid Flush & change
c) PUMP Relief Spring. These wear and Break, pump
is mounted under adapter plate
D) Clutch Pressure Spring (In control Spool Assembly) (sets Pressure @ 120 with clutch released)
E) COM/Convertor Pressure Spring (sets pressure @ 35 with clutch pushed in)
These are easy & cheap"
remember. These things are getting old and seals tend to go bad at times and will let the pressure go. Hope this helps.
rcw
11-02-2007 05:07:07
When the motor is running full speed, it feels like all of the power of the motor is not getting to the rear wheels. I do understand how Case-o-matic works, but over the last couple of years, the transmission/case-o-matic has weakened. This is a great pulling tractor and i would like to get it back in competition.
