Putting distributor on sc
JSTPA
11-01-2007 13:04:44
I'm switching my sc to a distributor ignition, I pulled this setup off another sc. The distributor sits vertical in a housing that bolts up to the governor.My question is should the housing be oiled to lube it, or just greased where the distributor gear meets the drive.The distributor # is 111411. Thanks for any help, jstpa
mEl
11-02-2007 17:32:39
 Re: Putting distributor on sc in reply to JSTPA, 11-01-2007 13:04:44
I have had several of these units over the years, my experience was that the old grease had hardened and was useless. I would take the plate off clean it good and put enough good grease in there that the gears can pick it up. better to make sure than to seize something or wear out a bushing.
C. Amick
11-01-2007 18:04:09
Some of the distributors have a threaded plug on the housing. I've seen people remove this plug and screw a grease fitting in instead. Not much lubrication is necessary, however.
jal-SD
11-01-2007 13:49:29
Shouldn't need any major lube, just oil in the oil hole. (My $0.02 worth. jal-SD)
