930 REAR END
LP PULLER
11-01-2007 08:35:55
IS THERE SUCH A THING AS A 930 CHAIN DRIVE SIX SPEED WTH A DRY CLUTCH
LenND
11-01-2007 18:59:56
 Re: 930 REAR END in reply to LP PULLER, 11-01-2007 08:35:55
If you check out a Case history book it will tell you that all six speed were chain drive. They changed that when they went to eight speed which was in the early sixties models. The first 930's were were 900B's with a 1/4 inch bigger sleeve and upped the rpm's a 100. Now I don't know about the wet clutch setup.
Racine
11-01-2007 12:53:39
Hello LP Puller,
You ask if there was ever a dry clutch "930", six speed chain drive tractor built, the answer is definately NO.
They were all wonderful tractors indeed in every way !!!
Regards
Alan T. Lewis
Christchurch
NEW ZEALAND
