my case 310 wont go
eric s
10-31-2007 17:11:54
i think its a clutch issue. it moves slowly on flat ground but inclines no. previous owner had clutch replaced and told me it was adjusted "all the way" anyone seen this before? is there an adjustment 2 b made?
C. Amick
11-01-2007 09:35:39
 Re: my case 310 wont go in reply to eric s, 10-31-2007 17:11:54
Is the hand clutch lever on the left pulled up as far as it will go? It stops the wheels but not the PTO. It's what's called a knuckle clutch. It should sort of latch in place.
eric s
11-01-2007 08:06:30
the problem started occuring when i shifted the lever to the right of the 4 speed gear shift lever. I believe that is the hi - lo selector? but i am not sure. or is it a hand clutch? where would the hand clutch be if i had one? thanks, eric
JRT
10-31-2007 21:01:09
Does it have a hand clutch also. If so it might be this one that needs adjusting. There is a fairly simple procedure where you take the front transmission cap off and go in and do it. I have seen this happen where they would still move but not go up hill.
eric s
11-01-2007 08:09:41
 Re: my case 310 wont go in reply to JRT, 10-31-2007 21:01:09
Joe (Wa)
10-31-2007 20:53:11
Do you have triple range, shifter fully engaged in 1 of the 3 positions? Do you have a hand clutch, fully engaged in the forward detent? Either of those levers can get bumped causing a no go & a red face I might add. Never happened to me, nope never did.
Joe
Bill64
10-31-2007 19:08:59
Eric,
Just replaced clutch on my 310 Utility. The book calls for 1/8" free play where the clutch rod enters the bell housing. Adjustment is made by loosening and turning rod to adjust. Better a little more play than not so clutch fingers do go not over center when depressed. Hope this helps. Bill
eric s
11-01-2007 08:11:05
 Re: my case 310 wont go in reply to Bill64, 10-31-2007 19:08:59
anyone have any kind of repair manual or know where to get one on this?
