CASE 1370 PTO PROBLEM
SCOTT CRAVEN
10-30-2007 17:57:39
The PTO shaft will not stop turning. The cable linkage is good, the flowdivider lever movement is good, pressure at "ease" at flow divider is 190psi, PTO clutch assembly has been rebuilt. The PTO would not stop turning even before the clutch assembly was rebuilt. Any ideas why it turns regardless of the position of the linkage?
Jim B
10-30-2007 18:37:59
 Re: CASE 1370 PTO PROBLEM in reply to SCOTT CRAVEN, 10-30-2007 17:57:39
Could be the PTO Brake Shoe is worn out.
The brake stops the shaft from spinning due to internal friction when clutch is disengaged.
Check out the 1370 parts manual pictorial on the Case IH website. Here's the link to the main page: Link
