LA fan belt....changing..
Dutchman
10-30-2007 17:18:35
Hi, I had to replace my gen.belt...broke into pcs..anyway ...if you have a La you know you got to remove the fan belt....that's were the the FUN starts... read the book on how to replace a fan belt...it left out ONE big thing...you really should take the rad. out or loose so you have some room... I decided to do it the HARD way...left the rad. alone... If you ever had to replace the belt you know the fun I had...only skin 2 knuckles and pinch a finger... Anyway it will be somthing that I will reminder for a long time... Just wanted too tell someone the Fun I had...
THANKS for listening.... Mark
Walter r. Davies
10-31-2007 16:36:28
 Re: LA fan belt....changing.. in reply to Dutchman, 10-30-2007 17:18:35
Sure glad mine are in good shape Crossing fingers as I write this.
Walt
Ande
10-31-2007 05:02:06
And to think you still love her after all that!We are a forgiving bunch arent we!
Ande
LenND
10-30-2007 20:02:01
I have a 900 and I worked on that for awhile before I found the solution. On the 900 you take the four bolts out of the center of the fsn and theres plenty of room. But I imagine the LA is different, huh?
Dutchman
10-31-2007 14:54:28
 Re: LA fan belt....changing.. in reply to LenND, 10-30-2007 20:02:01
O-YES...I must of forgot to say ...the fan was off...but you can't get it out past the shrout and try and twist it or walk it out was impossible....as least I didn't find the trick....
THANKS....for replying.....YES I still love it....Mark
LenND
10-31-2007 18:35:17
 Re: LA fan belt....changing.. in reply to Dutchman, 10-31-2007 14:54:28
Gee, here I had some important information, oh well. They didn't think a person was going to ever change them I guess. I have to take that stuff of to put the power steering belt on my 900B also. The first time I had the radiator off to get it cleaned so I replaced the fan belt and that was nice work then.
