VAC engine upgrade questions
Jim McVay
10-30-2007 17:01:01
I have a friend that wants me to hop up his VAC. I know the 300 cranks will fit but what will it take to put 530 sleeves and pistons in it or how can I go bigger. How can I get the maxium out of it and stay with the stock block.
FRAN400PULLER
10-31-2007 15:32:53
 Re: VAC engine upgrade questions in reply to Jim McVay, 10-30-2007 17:01:01
300 CRANK WILL NOT FIT IN THE VAC BLOCK IT IS TOO LONG.BUT EVERYTHING ELSE WILL WORK.USE A 530 GAS CAMSHAFT OUT OF A 159 ENGINE.MY VAC HAS THE 300 BLOCK WITH 159 PISTONS AND CAM.TOOK .200 OFF OF THE HEAD AND MATCHED THE MANIFOLD TO THE HEAD.IT PULLS VERY WELL FROM 2750#-4000#.
Jim McVay
11-01-2007 05:46:49
 Re: VAC engine upgrade questions in reply to FRAN400PULLER, 10-31-2007 15:32:53
I put a 300 crank in my VAC. I had to cut on it a little at the rear main. I put 300 piston and sleeves in it. My buddy wants a little more out out of his.
Charles E. McNelly III
10-30-2007 19:12:35
Cut .200 off of the head for starters. Seemed to wake up a buddys VAC. Out pulled a Farmall Super C at the last pull by 3 feet or so. Also went with the overbore kit as well. But if you plan on stroking it with the 300 crank, it won't hurt.
Good luck,
Charles
