Tractor wisdom,
kirk in ks,
10-29-2007 14:54:26
Ive got a choice between a JD 4520, or a Case 1070,
I kinda like the case's of then,
theJD was ok i guess, is the best thing to do on each one is to find a manual tranny, and stay away from the powershift,
as they can be kinda picky to deal with if your into longevity?
please help me on this as I like both of them but the JD's are kinda high as the people are kinda brainwashed by green paint , shoot ,,, I dont know?
Walt Davies
10-31-2007 16:23:01
 Re: Tractor wisdom, in reply to kirk in ks,, 10-29-2007 14:54:26
You know its just plain dumb to ask the guys on the Case list whether you should get a JD UGH or a Case tractor.
Take your question the JD people and you should get just the opposite answer.
Walt
Lamont
10-31-2007 05:08:17
I know this. Around here you can't give away a 4520. No one wants them. The 4620 is a different story, although they were much overated and not highly sought after either. Still nothing but a 4020 engine with a turbo. Many problems with lower end wearing out. There was one word mentioned in your post that caught my attention; longevity. Go CASE in the era you're considering. They are tough to beat.
JoeBob/IN
10-29-2007 18:58:54
We've had a lot of 70 series and one 90 series and had very few powershift problems, major ones anyways. Been able to fix them all myself so far too. I wouldn't worry about those powershift trannys myself.
Lincolnj
10-29-2007 15:53:27
Not sure if it matters to you but the 4520 has only a 1000 rpm pto that can't be changed. 1070 should have both 540 and 1000.
Gary from Iowa
10-29-2007 15:25:31
Kirk - We had both of the tractors you are wondering about. The 4520 is about 135 hp and the 1070 is about 108-110 hp. The 4520 was John Deere's first attempt with a Turbo from the factory. We had all kinds of trouble with ours. We could not keep the bottem end (bearings) together. When it was in the shop for the third time my father leased a 1370 Case. It never went back, we switch from John Deere to Case. I know, Case has had there problems also, but I still like them.
