630 questions
JGarner
10-29-2007 05:30:28
Got my 630's wiring harness all done, rebuilt generator from Valu-bit on with new keyed pulley (one on old Delco alt. last owner stuck on not keyed)and fired the old girl up after finding one "problem". Now, three of questions from you all. 1. Is neutral safety starting switch pt. no. A 20990 still available from Case or other wise? Had to jumper to make tractor start.
2. Gas gauge does not seem to be working (may not have enough gas in tank?? (<: ). Has anyone gotten these from NAPA if it is not functioning?
3. Oil pressure shows real low (2-5 psi). Engine rebuilt not too long ago with new rod and main bearings. Could the oil pump relief valve be stuck open? Is it adjustable? Former owner says he measured the pump with micrometer and it was within spec. Any other ideas?
