case 611 b
smokinbt100
10-28-2007 05:56:08
i have bought this tractor from a freind.it needs brakes,the steering has a lot of play and it turns very hard at first untill it is moving,it also has a dead short on the positive side ,it doesn't seem to be charging i wonder if its not because of the short ,there is power coming out of both wires on the genarator
JGarner
10-28-2007 17:14:03
 Re: case 611 b in reply to smokinbt100, 10-28-2007 05:56:08
When you put you volt meter on, it hooks up backward. Just got my 630 back together and running about an hour ago(next version of 611B) and its positive ground. Hook up the - side of your VOM to the Genny arm post and touch the + to ground. I will bet you show a charge, mine just did as I switched back to generator and positive ground.
smokinbt100
10-29-2007 07:30:12
 Re: case 611 b in reply to JGarner, 10-28-2007 17:14:03
great thanks,now it has a 12 volt battery ,not a 6 volt correct ?
JGarner
10-30-2007 09:27:08
 Re: case 611 b in reply to smokinbt100, 10-29-2007 07:30:12
Yes, 12V positive ground. And as to Caseman d below, I thought they were all negative ground to until I got the 630 and started digging into it and getting the Case books on it. I think the generator based 12V 1960-64 430/530/630 tractors were all positive ground.
Our 1963 830 was negative ground. It carried 2 12V group 27 batteries in parallel. Took a lot of stuff to turn that big ole diesel over when it was cold. Wonder how many batteries the 930 had??
Jim B
10-30-2007 19:00:03
 Re: case 611 b in reply to JGarner, 10-30-2007 09:27:08
Our 930 also has two 12V, group 27, batteries in parallel. Starts better than our 800 & 830 Diesel 4 cylinder girls. Same battery setup is also in our 4x4(s), 2470 (504 cubes) & 2870 (676 cubes).
It's not only about battery voltage and amperage but also starter motor design... I.E. output torque.
Phil Munson NY
10-28-2007 09:36:58
I do not know about your particular traactor but some cases of this vintage were 12 V POS ground.
caseman-d
10-29-2007 18:04:25
 Re: case 611 b in reply to Phil Munson NY, 10-28-2007 09:36:58
Thought all Case's were negitve ground or am I wrong???
caseman-d
