CASE 1370
Jeremy Willmott
10-27-2007 19:46:56
I recently purchased a Case 1370. Everything works good on the tractor , but the three point. I tried it today and I cant get it to raise or lower. It does nothing at all. Anybody got suggestions, where to start?
chess
10-28-2007 07:12:34
 Re: CASE 1370 in reply to Jeremy Willmott, 10-27-2007 19:46:56
Trans an hvd use common sump an i believe there is a fill hole at rear of tractor that has dipstick on cap. If no dipstick look for 2 small glass sight windows . Not sure which your tractor has. Than follow leaver in cab an its cable to hyd valve an make sure it is moving valve. You can also go to cnh web site an click on case an follow instructions to parts list an see parts list for your tractor.Recomend propercase oil
chess
10-28-2007 07:50:41
 Re: CASE 1370 in reply to chess, 10-28-2007 07:12:34
Looked at case site an you should have a fill hole at right rear corner of transmission . It is combination breather -fill hole an dipstick.If no dipstick on it replacement no is a153269.There is also good description ov valve an other parts on site.
