3 pt or eagle hitch
Vic D
10-26-2007 15:52:01
I have a 48 VAC Case, no 3 pt is it possible to install 3 pt or eagle hitch. Anybody done it and is it a major undertaking?
mj
10-30-2007 07:25:24
 Re: 3 pt or eagle hitch in reply to DKase, 10-26-2007 15:52:01
I put this one together 15 or 20 years ago and it has worked very well with no problems. It will pick up just about anything the tractor can handle without weighting the front end.
third party image
See more at:
Link
watsonsgotit
10-26-2007 17:26:08
 Re: 3 pt or eagle hitch in reply to Vic D, 10-26-2007 15:52:01
If you want to install an Eagle hitch, it can be done but you will need a rear end with the bolt holes in the casting for the rock shaft, the rock shaft, arms, hyd pump, lines, and may have to change torque tubes. If you have the center mount hyd clyclinder for lifting cultivators and the bail that goes to the back of the tractor for lifting implements, you might be able to rig up a three point hitch if you are good with a torch and welder. You probably won't be able to pick up anything heavy though. Might be just as cheap to purchase another tractor. You can never have to many!
