311 Front wheel bearing. Gas gauge?
Bernsy MN
10-26-2007 13:49:06
Anybody know what bearing number for front wheel& spindle on the 311? (Wide front). Did I read on here awhile back that the reason my gas gauge doesn't work is because I switched over to a 12 volt system, I suppose that could be tricky to remedy. Thanks for any advice. Bernsy
Joe (Wa)
10-26-2007 17:07:53
 Re: 311 Front wheel bearing. Gas gauge? in reply to Bernsy MN, 10-26-2007 13:49:06
For 311 & 311B hub.
Grease seal:
Case p/n G13053
Chicago Rawhide p/n 19211
Inner bearing cup: Case p/n G57451
Timken p/n LM48510
Inner bearing cone:
Case p/n G57452
Timken p/n LM48548
Outer bearing cup: Case p/n B12410
Timken p/n LM11910
Outer bearing cone:
Case p/n B12411
Timken p/n LM11949
The 6v gas gauge & sender require a voltage reducer in series with the wire connected to the ignition terminal on the gauge. The alternative is to change out the 6v gauge movement with same rated for 12v and install a 240 - 33 ohm 12v Stewart Warner or generic sender with RH swing float.
Roger Hornbaker does that kind of swap. [email protected]
Joe
