830 case-o-matic stuck in neutral
Jeff77
10-23-2007 20:53:23
I've looked all around this forum and haven't found anyone else with this problem...
I have an 830 case-o-matic stuck in neutral. I believe its a 1966 model. Any help would be much appreciated!
Jim B
10-24-2007 21:28:45
 Re: 830 case-o-matic stuck in neutral in reply to Jeff77, 10-23-2007 20:53:23
When you say "stuck in neutral" do you mean:
The manual shift lever is stuck?
The lever moves but doesn't engage any gear(s)?
The COM foot clutch doesn't engage?
What does the clutch pressure gage show?
More explanation please... we can go from there.
Jeff77
10-24-2007 21:51:13
 Re: 830 case-o-matic stuck in neutral in reply to Jim B, 10-24-2007 21:28:45
Hey Jim thanks for the reply. It was my gear shifter that was stuck in neutral. I couldn't get it into any gear at all. Today I took things apart so I could have a better look. I started by taking the gear shift out of the trasnmission. With a pry bar I was able to successfully move the transmission into gear. I was quite happy about this so I remounted the gearshift (a few times) and everything worked fine after this. About 2 years trying to find time to do this 4 hour fix! Oh by the way the problem was caused two years ago when I put the clutch in an drifted down a small hill only to find at the bottom of the hill I couldn't get it back into gear.
Jim B
10-24-2007 22:16:03
 Re: 830 case-o-matic stuck in neutral in reply to Jeff77, 10-24-2007 21:51:13
Good for you and the Ol' girl.
Case tractors seem to never die if only given a little TLC... even if a little delayed, LOL.
