spider gears
oldeb
10-23-2007 05:41:41
How hard to check them out/replace on my 1030? What else will need attention? I assume this is a split job - can"t be done thru the top? Wheels gotta come off, axles out, etc?? Not looking forward to it. I get a "squalling" noise when I turn unless I apply the brakes. Spider gears I guess?
Roger (Mi)
10-25-2007 05:01:14
 Spider gear inspection and removal in reply to oldeb, 10-23-2007 05:41:41
On a 1030 the fuel tank and driver's platform will need to be removed. Once the rockshaft housing is removed, the ring & pinion with the spider gears can be observed. To go any further, the purchase of a I&T shop manual is well advised. Most farm stores will have one.
Walt Davies
10-23-2007 15:09:01
 Re: spider gears in reply to oldeb, 10-23-2007 05:41:41
Pull the back plate off of the differential and you can get in from there. Walt
oldeb
10-24-2007 08:17:34
 Re: spider gears in reply to Walt Davies, 10-23-2007 15:09:01
Will we be able to repair it from there?
