511B
tuggle
10-23-2007 05:40:01
I need an instrument cluster for my 511B. There is one on ebay for a 900B. Is this the same cluster??? and will it fit the 500B???
Roger300(MD)
10-25-2007 10:30:14
 Re: 511B in reply to tuggle, 10-23-2007 05:40:01
I can't seem to find the gauges on ebay for the 900B, would you mind sending me the item number, would appreciate it, also you can be confident JC will give you the true facts and infor. about his gauges; Roger
[email protected]
tuggle
10-24-2007 09:59:13
Thank you for the come back. I will get in touch with you, JC, Thanks for all the info, Joe
Joe (Wa)
10-23-2007 20:03:12
Do you have your old panel that you can do some comparison?
I don't know much off-hand about the 500B or the 900B so this is just my opinion from comparing p/ns on the CaseIH site and having some cluster instrument board experience. I'll address the cluster instrument board only, I don't know if the whole dash is interchangeable.
1. The cluster board case is the same p/n as 500B, will fit right in the dash.
2. The cluster shown has a 0-60 psi engine oil gauge. The 511B oil gauge is p/n G45024, 0-30 psi.
3. The tachometer shown has a left to right pointer sweep. 500B tach p/n on CaseIH site is listed as G45022, that is right to left pointer sweep.
4. The 900B gas & amp gauges are the same p/n as 500B. Speedo p/n is last digit off, sweep & range is correct, would bet it will work ok.
5. Seller states the temp gauge line is cut (the capillary tube is cut) meaning the temp gauge is junk unless you can find a instrument repair facility that can repair it, cost will be $200 plus. Roger Hornbaker can retrofit an electrical temp gauge w/sender that will be accurate and look original. 6. On the tach & speedo drive turning freely doesn't mean the brass drive hasn't been twisted off the drag cup (common). Ask the seller if the pointer jumps when the drive is spun, not definitive but if the pointer doesn't move it is junk.
Anyway, the short answer is no, it is not the same cluster but could be made to work with some gauge changes plus some bucks.
I would recommend that if you are serious about a restored cluster or having yours repaired contact Roger.
[email protected]
Joe
jcmarleau
10-23-2007 19:19:56
I do have what seems to be a very good one from a 511B but have not had the chance to remove it from tractor yet. If you e mail me later I may have a chance to take it off . my e mail is [email protected]
Joe (Wa)
10-23-2007 20:12:18
 Re: 511B in reply to jcmarleau, 10-23-2007 19:19:56
Sorry JC, was writing when you posted. You are very well spoken of by Roger, good enough for me.
If you see any errors in my post, please correct them.
Joe
