sc Distributor from magneto
911oldschool
10-22-2007 15:59:27
I Posted a while back, about converting my magento over to a Distributor system... After getting most of my parts, the fun has now begun.
My Question: I Ended up getting an "ac delco 90 degree distributor". were these 12 volt units? If not how can I tell what I have, short of trying 12v and watching to see if it smokes?
Thanks in advance.
Walt Davies
10-23-2007 15:04:02
 Re: sc Distributor from magneto in reply to 911oldschool, 10-22-2007 15:59:27
Everything is the same coil condenser and points just go to NAPA or any auto pars store and get a Balance resistor for it. Hook this between the on off switch and the coil. Walt
911oldschool
10-23-2007 17:04:32
 Re: sc Distributor from magneto in reply to Walt Davies, 10-23-2007 15:04:02
Thanks I appreciate the responses. It's these "small" things that are stumping me.
Gene Dotson
10-22-2007 16:10:13
The distributor doesn't care if it is 6 or 12 volt. If you are running a 12 volt system, you will need a 12 volt coil or a voltage reducer resistor for the coil... Gene
911oldschool
10-22-2007 16:25:04
 Re: sc Distributor from magneto in reply to Gene Dotson, 10-22-2007 16:10:13
The Condensor wont burn out if it is 6v? That would be great! I Do Have a 12 V coil standing by if this one doesn't generate a hot enough spark.
Thanks
CENTAUR
10-22-2007 16:43:33
 Re: sc Distributor from magneto in reply to 911oldschool, 10-22-2007 16:25:04
Condensers are the same.Coils are different. CENTAUR
CENTAUR
10-22-2007 16:42:15
