Negative ground back to positive ground
JGarner
10-22-2007 05:58:35
I have gotten a rebuilt 12v generator and new VR for my Case 630, built a new wiring harness and now, as soon as I can find a pulley the right size with a keyway in it (one on the alternator that was on it didn't have a keyway!!)I can finish hooking everything up. BUT... I need to polarize the generator. I can find instruction on line for negative ground systems but how does this differ for positive ground? Can anyone give me the proper procedure to polarize my rebuilt generator on my positive ground system?
Old Ford Mechanic
10-22-2007 19:22:49
 Re: Negative ground back to positive ground in reply to JGarner, 10-22-2007 05:58:35
Just touch the jumper from the "armature post to the battery terminal on the VR".Do not hold it there for a"couple of seconds".As soon as you touch it it should arc.That is all you need.You will need to reverse your wiring on the coil and on the ammeter.
JGarner
10-22-2007 20:12:16
 Re: Negative ground back to positive ground in reply to Old Ford Mechanic, 10-22-2007 19:22:49
Thought so. I have already hooked up the ammeter per the drawing and Case color code in the Case service manual so it should work OK. If it works back ward then I know to swtich the wires. The coil looked to be hooked up like that picture too, but somebody could have turned it 180 degrees in the mounting bracket so that"s why I was wondering if there is a plus and minus stamped on it I need to match.
Walt Davies
10-22-2007 09:40:58
Its exactly the same procedure for both. Remember what you are doing is polarizing the generator to match the polarity of the battery.
Walt
JGarner
10-22-2007 14:00:54
 Re: Negative ground back to positive ground in reply to Walt Davies, 10-22-2007 09:40:58
Walt, the clarification I need is that I arc the BAT terminal on the VR to the ARM terminal for a couple of seconds. This should "magnetize the generator armature to which ever system that BAT is on either positive or negative ground, right??
Also, I haven't taken the coil off to look at it, I just hooked my white wire (Case color code from my Case service manual) to the terminal it came from. The wire to the distributor stayed in place. Will these need to be switched for positive ground?
Thanks for you response.
Jim
Jerry W
10-22-2007 20:22:45
 Re: Negative ground back to positive ground in reply to JGarner, 10-22-2007 14:00:54
Jim The coil should be wired the same as your battery. If the positive cable of your battery goes to ground then the positive post of your coil should go to ground thru the points in your distributor.
It will work the other way but spark potential will be less because the 2 windings in your coil will collapse against each other instead of together.
Jerry
JGarner
10-23-2007 06:40:06
 Re: Negative ground back to positive ground in reply to Jerry W, 10-22-2007 20:22:45
Jerry, thanks. I assume then that the posts on the coil are marked +/- right?? Just want to make sure I hook it up correctly when I switch back to Case spec. The old coil has been painted over a couple of times and I am concerned about seeing any markings. Guess I could always pony up the bucks and get a new one, but this one seems to work OK.
Jim
