Case 2470 turbo upgrade
Mike S 806/H
10-21-2007 20:38:15
I need to buy a new turbo for the 2470, I heard the was a better turbo to get, anybody know what it is?
4435
10-21-2007 20:58:05
 Re: Case 2470 turbo upgrade in reply to Mike S 806/H, 10-21-2007 20:38:15
Mike, I replaced mine with one from Blaylock diesel here in Baxter springs, KS. It will max out about 16 lbs of boost. Blaylock also said they could increase the output of the garret if so desired.
the part # they set up for me was 313184. You can also use a schwitzer 3LM466 but have to use a spacer under the air cleaner and I used a 1/8 under the exhaust flange and am going to put one under the intake elbow at the intake manifold, probably 3/8 to help with alignment problems. I saw maybe one pound of difference in boost pressure. HTH Tom
