Case VAC Bearings and Seals X reference List
Farmer Jack
10-21-2007 18:50:30
I found a bearing and seals cross reference list for VAC Case tractors. I am working on a couple and sure could use that list. Where does one find it?
Paul f
10-22-2007 05:17:34
 Re: Case VAC Bearings and Seals X reference List in reply to Farmer Jack, 10-21-2007 18:50:30
I have a case manual from 1968 that lists ball and roller bearing Cross references. Have also worked up a list of some seals for VACs ...what do you need.
Farmer Jack
10-22-2007 11:14:16
 Re: Case VAC Bearings and Seals X reference List in reply to Paul f, 10-22-2007 05:17:34
I need the bearings for the VAC from the clutch rearward and the seals for the torque tube rearward.
Thanks,
Jack
C. Amick
10-23-2007 10:14:05
 Re: Case VAC Bearings and Seals X reference List in reply to Farmer Jack, 10-22-2007 11:14:16
You should be able to find the old Case part number on the CaseIH.com web site. Email me if you can't find them. I think I may also have a VA seal list at home that describes the location of the part.
Paul f
10-23-2007 06:02:31
These are all the VAC seals I have cross ref for. I would need to know the case part # for the bearings you are interested in to look up if there is a cross reference
pfrederi1 @ hotmail.com (leave out spaces) Sorry this is not very legible I can't paste a spreadsheet in here email me
Old# New# CR# Nat#
O4240AB A26777 13614 472287
O7610AB 19301 472144
VT2090 17557 450183
VT2095 21098 450365
VT2115 A30302 11776 473426
VT2233 A30323 13612 472287
VT2316 A29984 15748 450803
VT2817 9998 471689
VT2905 4985 410119
VT3249 33712 415894
VT3373 21143 450115
VT3401 11801 471765
VT3460 26209 455003
VT3465 A30501 22446 450316
VT3502 26209 455003
VT3520 A30507 13739 473215
VT3525 6203 471466
VT3555 13614 472287
VT3688 9876 470120
VT3749 A30526 25745 455280
VT3756 A30527 13650 471192
VT3757 13650 471192
