case 600 psb pump
josh kuhn
10-21-2007 17:31:42
I think im geting diesel fuel in my crankcase oil were should i start looking it has a american bosch psb pump tkanks.
Doc Larry
10-24-2007 15:39:56
 Re: case 600 psb pump in reply to josh kuhn, 10-21-2007 17:31:42
Thanks Ken,
Sounds like I should be able to change out the seal without much trouble (when I get some time).
Larry
Doc Larry
10-22-2007 05:49:57
Ken,
Can this seal be replaced by going in through the transfer pump without pulling the entire pump? I need to fix mine when I get around to it (!)
Thanks, Larry
Ken in AZ
10-22-2007 06:56:18
 Re: case 600 psb pump in reply to Doc Larry, 10-22-2007 05:49:57
I pulled the transfer pump off mine by removing 2 fuel lines and 2 bolts. Everything slides out so you can work on it easily without removing the main pump. Didn't find anything that required alignment so I cleaned it up, moved the seal slightly, installed a new shear pin (mine sheared off because of of rust) and it's back in operation.
I didn't replace my seal so I don't know what the part number is.
Hope this helps.
Ken in AZ
Ken in AZ
10-21-2007 20:08:51
There's a seal on the back of the transfer pump (on the drive shaft) that can allow leakage into the crankcase (well, there is on my 400). Check this first. I moved mine on the shaft as it had worn a groove in the shaft and looked like it was going to leak. It seemed a lot tighter after that so I put it back together and it runs fine.
Hope this helps.
Ken in AZ
