Case 530 vac propane
Rusticater
10-21-2007 14:58:20
My friend has what he believes is a case 530 vac, very tall, its propane and looks like it came from factory like that,he just bought it a year ago, serial # plate is missing,it has a wix oil filter # 51104, which is obsolete,he said instead of the filter screwing onto the nipple,the nipple is made onto filter and screws down into reciever,does anyone know of another oil filter that will fit this tractor,appreciate your help!
Joe (Wa)
10-21-2007 22:51:38
 Re: Case 530 vac propane in reply to Rusticater, 10-21-2007 14:58:20
third party image
Wix 51104 is now p/n 57011. Napa sells Wix filter 57011 as p/n 7011. Baldwin makes the same filter p/n T300-M.
Subject filter fits a base like this picture and has an external rolled thread with rubber seal(no nipple) same diameter as a standard mason jar.
When you unscrew the old filter, lift straight up to avoid breaking off the stem tube. Without that tube, the oil just dumps back into the crankcase w/o passing through the filter media.
Joe
Rusticater
10-23-2007 15:43:10
 Re: Case 530 vac propane in reply to Joe (Wa), 10-21-2007 22:51:38
Thanks a lot Joe,appreciate the info,Dave.
