1370
Todd L
10-19-2007 15:07:46
How hard is it to tighten a parking brake in a 1370 and how do you know when the parking brake is shot?
Hilltopper46
10-20-2007 18:32:02
 Re: 1370 in reply to Todd L, 10-19-2007 15:07:46
If you have the 1370 with the band style parking brake, the adjustment is on the end of the parking brake handle. Turn the handle clockwise to tighten the cable and the brake.
Frankly - these band-style parking brakes were pretty much useless. A lot of people in hilly country put a Mico-lock kit on the tractor. Case used to sell a Mico-lock kit for them but doesn't any longer.
happysmith
10-20-2007 07:33:45
I have a 1978 1370 and the parking brake doesn"t have an adjustment. The parking brake is a mechanical pawl that looks a bit like a gear tooth.
When the shift lever is placed into the parking position the brake is engaged and the pawl goes in between the teeth of a gear in the transmission. This locks the rear end to prevent the tractor from moving.
The pawl usually gets broken when someone tries to put the tractor in park when the tractor is still moving which snaps the pawl off.
The pawl is made out of a porous metal that is softer and easier to break than the gear teeth it meshes with so no damage is done to the transmission when the pawl breaks.
You have to pull the rear cover off of the rear end to get to the pawl. It"s not hard to replace. It"s just a big job to drain the oil and pull the rear cover.
