david brown 990 lift stuck
edward sheehan
10-19-2007 06:10:40
hi
unable to get lift to go down. selectamatic i think. 4 cylinder diesel. any help appreciated.
Roger Digre
10-30-2007 17:16:00
 Re: david brown 990 lift stuck in reply to edward sheehan, 10-19-2007 06:10:40
I have the opposite problem. My lift will not go up. Will those adjusting valves work for this problem. Is it possible there could be rust on the valves. Had moisture problem last winter. Also that lever is used to keep lift locked in upright position.
efs
10-30-2007 18:25:52
 Re: david brown 990 lift stuck in reply to Roger Digre, 10-30-2007 17:16:00
hi roger
right now my lift won't go up. tomorrow i am getting a hydraulic filter and some hytran to change them and see if that helps. right now fluid looks like vanilla pudding. let you know.
Roger Digre
10-30-2007 21:08:12
 Re: david brown 990 lift stuck in reply to efs, 10-30-2007 18:25:52
All that was changed last winter lift still would not go up. Fluid looks good now.
Roger
edward sheehan
10-31-2007 04:16:25
 Re: david brown 990 lift stuck in reply to Roger Digre, 10-30-2007 21:08:12
hi roger
try turning those 2 screws under the plate i described. that got mine going. i will post back after i change fluid. ed.
Roger Digre
10-31-2007 16:18:59
 Re: david brown 990 lift stuck in reply to edward sheehan, 10-31-2007 04:16:25
Thanks will try that.
Roger
edward sheehan
10-21-2007 09:40:42
got lift down! just behind the lift control lever is a small plate held in by 2 flathead phillips screws. under that are 2 adjusting valves. with tractor running, i turned the one nearest to center of tractor counterclockwise maybe one full turn and lift slowly came down. moving control aft picks up lift quickly; moving control forward lets it down slowly, but it does come down. yea. ed.
edward sheehan
10-21-2007 08:16:01
hi jim
i have changed setting of that lever-it was in now out. lift still stuck. what else can i try?
thanks. ed.
jim in north texas
10-19-2007 07:02:12
there is a lever on the left side at the rear to lock the lift arms in the up position. pull it out and turn it to the off position.
efs
10-19-2007 08:53:06
 Re: david brown 990 lift stuck in reply to jim in north texas, 10-19-2007 07:02:12
hi jim
thanks for reply. do you mean the rounded lever that says push to engage? ed.
