830 case-o-matic
Nedd
10-19-2007 05:38:36
Does any one know if the COM from the early dual range 830's will fit into the very early single shifter 830 COM? I've have already swapped motors 7 years ago but now the COM on the single shifter is starting to slip under load.( A LOT of hours) The dual range had a noisey rear end and jumped out of hi under load, that was why I swapped motors. It looks like the same housing and valve body on the side. The pumps were a little different on the suction tube but just hoping the shaft into the actual rear end is the same. Thanks for any and all input.
John Saeli
10-19-2007 17:13:56
 Re: 830 case-o-matic in reply to Nedd, 10-19-2007 05:38:36
yes, they will swap.
