case va govenor linkage
Peter Hendricks
10-18-2007 15:17:21
how many springs are there on the linkage between the carb and govenor and the govenor and the throttle? does any one have a picture they could email me?
thank in advance
Pete
Joe (Wa)
10-18-2007 21:53:34
 Re: case va govenor linkage in reply to Peter Hendrickson, 10-18-2007 15:17:21
There is no spring between the carb and gov. People often add one to return the carb linkage to idle when the gov is not working properly.
There are two springs between the gov and the throttle, one spring (control spring) connects the gov arm to the throttle rod and the other is on the speed lever to return the foot throttle to idle.
Go to the link and click on page G2 S26 for control spring location and the next page G2 S27 for the speed lever spring in the VAI pix.
Joe
Joe (Wa)
10-18-2007 22:05:29
 Re: case va govenor linkage in reply to Joe (Wa), 10-18-2007 21:53:34
I should add here that if your tractor is '49 or earlier the throttle (control) rod and bracket may not look like the pix in page G2 S26. The control spring on the gov arm connects to the throttle in a different way.
I can't find a pix of that, perhaps someone else can help.
Joe
