case 400 disel
Ralph P. Stults
10-16-2007 17:09:05
I need info on fuel transfer pump on the injection pump I don't think mine is working. When I close the by-pass it stalls out and with it open it lacks power. Dose any know if this can be repaired and what it takes to do it?
Ken in AZ
10-16-2007 20:13:35
 Re: case 400 disel in reply to Ralph P. Stults, 10-16-2007 17:09:05
My experience with a 400 Diesel with the PSB pump:
The transfer pump has a pin on the shaft that will shear if something gets in the pump. Transfer pump is accessable via 2 bolts and is a gear type pump with 2 fuel lines going to it on the side of the main pump. You might want to take it apart and clean it up real good.
I also moved the seal on the shaft slightly so as to make sure it wasn't running in a worn spot on the pump shaft as it could leak fuel into the engine oil.
When the shear pin snapped it was due to rust in the pump on mine. Saved the pieces and made another one from rather soft steel with a mill, a file and some time.
Hope this helps. Email me if you want more details on what I did.
Ken in AZ
ross400diesel
10-18-2007 07:00:10
 Re: case 400 disel in reply to Ken in AZ, 10-16-2007 20:13:35
On our 400 diesel we had a similar problem and it was the gear in the fuel pump in the injection pump. The pin had sheered off and the gear was out of place so we just got a salave injection pump.
J Schwiebert
10-16-2007 19:26:43
You have gotten good advice. I would change all the filters and then check the pressure of the low pressure side. More questions. By the way that PSB pump will work on 5 psi. J.
Doc Larry
10-16-2007 18:11:48
Have you followed the complete bleeding procedure in proper order as per the owner's manual, and are all the filters clean? The first stage filter can look okay, but be clogged with gum. It shouldn't run good with the bleeder valve open, by the way.
Larry
