Hydraulic Brakes on Case LA
LaLaLand
10-16-2007 08:12:42
ok, so it's one of the last major things to tinker with on the LA and these Wagner Lockheed hydraulic turning brakes (both master and wheel cylinders) have had water in them for years! i've freed up the master cylinders, but the wheel cylinders are still frozen. having talked to a couple of Case guys i know, they say this brake was always trouble and few folks ever kept them working! to fix the ones i have, i think i would have to sleeve them with brass and go for an oversized kit. a lot of trouble! here in AZ i can't find the re-build kit for either. so that's my dilema. going to put a want ad here for the cylinders soon, but thought i'd check with some of the experts first. any advise would be greatly appreciated!!!
rick
Alan Golden
12-05-2007 19:12:57
 Re: Hydraulic Brakes on Case LA in reply to LaLaLand, 10-16-2007 08:12:42
I can tell you that the original Wagner parts numbers are no longer valid. The master cylinder was FE1050, kit FC5375, wheel cylinder FC1757, and kit FC3618. I went to the local NAPA store and they called Wagner and they couldn"t be found using those numbers. Apparently Wagner has changed the numbers, if they even still carry any parts for them.
Ande
10-17-2007 05:56:34
LaLaLand
I"m on the same page as you,just starting to figure out what I need.Lets stay in touch,not sure how much I"m going to get done as this "LA" is in my summer shop.But my plans are to take of these parts and get them redone.I have a friend that has told me he can get the parts.
Ande
Dutchman
10-16-2007 16:50:21
I think I can come up with some #'s if your interested...I think they were wagner lockhead E-mail me if interested ...then I will try and find then...have a good idea where to look Mark
Gene Dotson
10-16-2007 09:20:30
Rick;
I have wheel cylinder cups. Had to buy a box of 10 to get the 4 I needed. Honing the cylinders good will likely make them servicable and you can reuse the plugs and expansion springs.
New master cylinders are available from Wagner. There are 2 cylinders that will replace the LA cylinders. Sorry I don't have the numbers.
The secret to keeping them working is to apply them often. Regular use keeps the cups and bores lubricated... Gene
