SC clutch noise?
SeanM
10-15-2007 20:36:55
I have a 1948 Case SC. It had been used on our farm for years. Farm got sold but I snagged the tractor and bush hog. Using it to clear brush on some property I bought. When I am engaging the clutch it makes a popping noise but goes away once the bush hog (6 footer) gets spun up. 15 years ago, before the tractor sat, it didn't make this noise. Is this just the clutch slipping or something worse? Bearings, gears? Belt pulley does have some play.
C. Amick
10-16-2007 09:09:01
 Re: SC clutch noise? in reply to SeanM, 10-15-2007 20:36:55
Did you drain the oil from the clutch housing when you changed the engine oil? Does it only make the noise with the PTO engaged? If so, it could be a PTO shaft bearing and not the clutch.
SeanM
10-16-2007 10:44:36
 Re: SC clutch noise? in reply to C. Amick, 10-16-2007 09:09:01
Yes, I drained the oil from the clutch housing. Nothing out of the ordinary when I drained it. I haven"t heard it make the noise any other time but I really don"t put any strain on it other than using the bush hog. If I don"t have it in gear and just engage the PTO with the bush hog it doesn"t make the noise. I pulled the side cover off to look at the shaft and see if it moved any direction but rotationally and I couldn"t see any odd movement. I was only rotating it from the pulley so maybe I couldn"t put enough force on it.
