Shift problems on 5140
kidder
10-15-2007 10:50:46
This message is a reply to an archived post by wc on September 06, 2003 at 18:40:22.
The original subject was "Shift problems on 5140".
forward reverse solenoid valve is sticking. its located on top of gearbox under the cab at the back. i put shuttle handle in forward and give mine a tip of a spanner but make sure gear handles are in neutral or else tractor will move off. solenoid unit needs to be cleaned probably. bit of grit causing valve to stick
