SC Case dual wheels
AMISHBOB
10-15-2007 10:30:13
Isit possible to make an sc into dual rear wheel tractor?I have 2 SC"s 1 for parts ,I have the center part of the wheels but need the rims it sure would be good for some of my wetter low ground next spring .
C. Amick
10-16-2007 09:29:30
 Re: SC Case dual wheels in reply to AMISHBOB, 10-15-2007 10:30:13
This seems like it would be easier to do if you had a set of the longer axles (Part No. 04515AB). They were 8-inches longer than the standard SC axle.
John Noname
10-15-2007 15:25:53
The only dual SC I ever saw was at the Summer Case show when it was held in Hastings, MN a few years ago. This one was special ordered from the factory. The fenders were set in which made things a little narrow. If you can get the wheels bolted together it should work.
J kemp
10-15-2007 20:09:19
 Re: SC Case dual wheels in reply to John Noname, 10-15-2007 15:25:53
What in the world FOR ,,All sc I have known would not have enough power to pull the HAT OFF YOUR HEAD.. However it is very possible to set the old girl up with duals , plenty of room on the axle, Just gonna make it a tight operator area ,, Pardon My jab,I simply have a low opinion of the sc as oppposed to the mighty DC and tough Spirited Thrifty VAC.
