Need a carb kit for a 711B
Aaron Ford
10-14-2007 20:03:41
My friends 711B is having carb trouble and I thought I would pick up a kit and go through it. It is a Mavel Schebler, but I have no idea what carb number or where to find a kit. Thanks in advance, Aaron
Don L.
10-15-2007 06:10:31
 Re: Need a carb kit for a 711B in reply to Aaron Ford, 10-14-2007 20:03:41
To get a kit with a throttle shaft, buy a carb kit for a U Minnie Mo, pull the pin on the old throttle shaft quadrant and copy the positions of the old shaft. Everything else is the same.
Don L.
charley hellickson
10-14-2007 22:38:19
Hi Aaron.
Try NAPA, they have the Echlin kits for a lot of stuff. I was told years ago at my Dodge dealer that Echlin is the best kit, has more parts in it. I use them. Carquest also has a lot of tractor kits. Standard is an old name in carb kits if you can find someone who sells them. Standard makes ignition stuff. I chacked Carquest once for a carb kit for a VAI and they could get it and a lot of other Cases.
Charley.
