Help Identify-- May be Case 300
Fillroy
10-14-2007 17:55:35
Tractor has no sheet metal, no ID tag on dash. Tricycle front end..12-3 transmission..engine number 11CN02584..Casting number G1000..Date code on transmission housing 5-29-28.
Thanks in advance.
Fillroy
charley hellickson
10-14-2007 22:49:10
 Re: Help Identify-- May be Case 300 in reply to Fillroy, 10-14-2007 17:55:35
Hi Fillroy.
What size tires, is the big casting on the front rounded or square? The 300 had the serial plate on the dash under the steering wheel. The 300B had it on the rear left side of hood.
Thanks. Charley.
Joe (Wa)
10-14-2007 18:19:14
Yes it could be a 300 series tractor but you need to take another look at your nrs.
Engine serial nr 110N+5 digits & 110M + plus 5 digits is commonly found on model 311 tractors so check your 3rd character.
Casting nr G1000 is the block for the 148 cid engine common to 300 & 300B series and a few other series tractors.
Date code can't be 5-29-28, but if it is a date code at all it could be 5-29-58 and may be found on a 300B series tractor as well as any model tractor built in the '58, '59, etc model year(s).
